1. AC Question's Avatar
    Hello,
    My LG G3 broke a few weeks ago so I had to take in use my old LG G2, however the problem is that it was rooted and xposed was installed. I did a factory reset via settings in android and everything seemed to be fine except supersu can't be found in menu, however I can open it via google play. Then I checked via root checker and it does not seem to be rooted and supersu does not work as well. This is not an issue to me, this will be just a temporary phone for a month or so so no root is required but snapchat is not working at all. Snapchat worked before factory reset but now I receive error “Oh no! Your login temporarily failed, so please try again”.
    Is there any solution to get it to work?
    02-07-2016 01:19 PM
  1. Google Play Music notification bar is HUGE
    By Dwight Jones in forum Ask a Question
    Last Post: 05-17-2016, 02:57 PM
  2. Why does my phone not let me type?
    Last Post: 02-07-2016, 02:33 PM
  3. why is my battery draining fast?and its heating.
    By Raj kadam in forum Ask a Question
    Last Post: 02-07-2016, 01:15 PM
  4. why is my battery draining fast?and its heating.
    By Raj kadam in forum Android 4.4 KitKat
    Last Post: 02-07-2016, 12:47 PM
