1. Steevo1289's Avatar
    Working on a Galaxy S5, around 1.5 years old. Battery started to drain super fast around two weeks ago, figured it was just old battery, so bought a new one through Verizon. Even with the new one, battery was still dying quickly, so I went through a factory reset to clean it all up.
    Result: battery meter still reading as if battery can't charge above 66%. I'm figuring it's something with the software, but have no idea what else to clean up :/
    02-08-2016 10:39 PM
  2. Tech-Newb's Avatar
    Can you post a screenshot of the battery usage on settings from full to around 20-30 percent left.
    Have you recently moved to a new area? You might have poor signals which cause battery drains. Does your phone heats up often? Or maybe you got a bad new battery.
    Posted with ❤Love❤
    02-09-2016 05:41 AM
  3. Tech-Newb's Avatar
    Your battery meter can't go above 66 percent? Try to factory reset it again. Or re-flash your phone via odin. Guide on how to re-flash is available on the internet and it's easy to do.
    Posted with ❤Love❤
    Posted with ❤Love❤
    02-09-2016 05:43 AM
  1. video playback problems
    By Magicman1005 in forum Samsung Galaxy S6
    Last Post: 02-09-2016, 07:19 AM
  2. Can I retrieve info from Galaxy S3 with dead screen?
    By AC Question in forum Samsung Galaxy S3
    Last Post: 02-08-2016, 10:38 PM
  3. Replies: 1
    Last Post: 02-08-2016, 10:36 PM
  4. How can I get rid of urls' in incognito on my Galaxy S6?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 02-08-2016, 10:33 PM
  5. Replies: 1
    Last Post: 02-08-2016, 10:29 PM
