1. AC Question's Avatar
    My nexus 6p only charges to 96% then stops. if I plug out and plug the charger back in, it will continue to charge to 100%. anyone can help?
    02-13-2016 01:30 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try calibrating the battery software by charging up to 100%, then using it normally until it shuts off from low battery. Charge back up to 100% again, and repeat the cycle 3 times. Does it keep stopping at 96%?
    Also, are you using the original charger and cable?
    02-14-2016 01:01 AM
  3. Nudgedoink's Avatar
    thank you. I will try out your tips. Yes, I am using the original charger and cable. Will let you know after 3 cycles if this issue still persists. I do not have an issue with battery life however, and I do agree that it may be software related (calibration) and not a bad battery. do correct me if I am wrong.
    B. Diddy likes this.
    02-14-2016 09:18 AM
  1. swype function on samsung keyboard stopped working
    Last Post: 11-08-2016, 05:28 PM
  2. how to turn off predictive text in my huawei p8 lite
    Last Post: 09-03-2016, 09:22 AM
  3. Battery usage has suddenly doubled
    By Jezza819 in forum LG G4
    Last Post: 02-17-2016, 12:40 PM
  4. Replies: 1
    Last Post: 02-13-2016, 01:44 PM
  5. Why can't I log in to my phone.
    Last Post: 02-13-2016, 01:40 PM
