1. AC Question's Avatar
    So my phones power button broke and I can't fix it
    02-13-2016 06:05 PM
  2. lephils's Avatar
    Look up "Gravity Screen" in the play store.
    Best settings I found was to go to sleep by turning the phone upside down, and waking by the proximity sensor. Those options seem both reliable (but I guess it depends on the phone's sensors) and battery friendly.
    02-13-2016 06:27 PM
  3. Rukbat's Avatar
    The only way other than having the switch replaced is to solder wires to the switch contacts and short them to activate the switch's function (long short for menu, short short for screen on-off).
    Putting the phone to sleep isn't turning it off. And you can't install the app unless you can turn the phone on.
    02-13-2016 09:35 PM
  4. lephils's Avatar
    Yeah, you're right, I thought only about turning the screen on and off.
    Could have been a temporary solution for the screen if the phone has been powered on...
    02-13-2016 10:07 PM
  1. tap to pay stopped working.
    By Mike Norton in forum Samsung Galaxy S6
    Last Post: 02-16-2016, 11:11 AM
  2. Replies: 1
    Last Post: 02-13-2016, 10:00 PM
  3. How to fix broken GPS
    Last Post: 02-13-2016, 09:42 PM
  4. How can I move my photos from Gallery to Google Photos?
    Last Post: 02-13-2016, 09:40 PM
  5. Why does my phone get extremely laggy?
    Last Post: 02-13-2016, 05:17 PM
