1. AC Question's Avatar
    Here are some specs for my phone:
    Android Version: 4.4.4
    System Version: 212.44.26_att.ATT.en.US
    The phone used to be on AT&T, but I bought it unlocked from Amazon, and now I use it with a prepaid plan from T-Mobile.
    I'm trying to get from 4.4.4 Kit Kat to 5.1 using OTA
    This won't let me post links, but I'm using this file: Blur_Version.212.44.26.ghost_att.ATT.en.US.zip
    I get the error message:
    Verifying current system…
    “/system/etc/install-recovery.sh” has unexpected contents.
    Installation aborted
    Can anyone help? I'd like to get my phone updated. Some of my apps are giving me issues because I'm not on Lollipop.
    02-18-2016 07:31 PM
  2. nahoku's Avatar
    Have you tried taking it to an ATT store and have them update LP for you. It's still their phone.
    02-18-2016 08:46 PM
  3. Aaron Harrison2's Avatar
    I've been talking to T-Mobile, and they suggested I contact Motorola, but they really didn't help me out either.
    So AT&T would be the store to take it to?
    (Also I'm the person who posted the original question
    02-18-2016 09:03 PM
  4. nahoku's Avatar
    There was a woman here who had an ATT phone, using it on T-Mobile. She ended up going to ATT and having them upgrade her phone to LP.
    As you must have noticed, even if you check for updates, the phone won't update. Its because you're on another carrier than the original carrier and they don't have OTA's for it.
    02-18-2016 09:22 PM
  5. Ashtroid666's Avatar
    Man, that seem so complicated.
    02-18-2016 09:30 PM
  6. Aaron Harrison2's Avatar
    Thanks for the help. I thought about doing that, but I wasn't sure if they would give me trouble for it because I wasn't on their service.
    02-18-2016 09:33 PM
  7. nahoku's Avatar
    It is what it is.
    All you can do is try. They may give you static, but try to find someone who'll help.
    02-18-2016 09:50 PM
  1. Please Help.. Issues!
    By austin 67 in forum LG V10
    Last Post: 02-19-2016, 08:38 AM
  2. Stolen tv help
    By josh3035 in forum Google TV
    Last Post: 02-18-2016, 08:18 PM
  3. Replies: 0
    Last Post: 02-18-2016, 07:10 PM
  4. Replies: 0
    Last Post: 02-18-2016, 07:08 PM
  5. S6 is deleting my email from the server, is IMAP not POP3
    Last Post: 02-18-2016, 07:01 PM
