1. AC Question's Avatar
    I just bought this s6 edge plus and it is a Verizon phone. my current provider is metro pcs. I had my sim transferred. Calls work just fine. Txt messages are delayed and some not received. Most of all, the internet data doesn't work at all. Only works when connected to wifi. metro pcs access point name cannot be located.
    02-20-2016 12:40 AM
  1. Honor 5x USB to PC
    Last Post: 09-05-2016, 02:25 PM
  2. Trying to create an odd shortcut
    By Defender1970 in forum Ask a Question
    Last Post: 02-20-2016, 09:37 PM
  3. sd card isnt working on my computer
    Last Post: 02-20-2016, 03:52 AM
  4. Replies: 0
    Last Post: 02-19-2016, 11:38 PM
  5. after an update my verizon 4g lte g4 will not restart
    Last Post: 02-19-2016, 10:54 PM
