1. AC Question's Avatar
    Im using a galaxy note 3 for almost a year now. The problem is, from the past 2 months the battery backup is very low. Its going from a 100% to 1% in less than 3 hours. Even if im leaving the phone idle its discharging really fast. I have replaced the battery. But the issue stays. And i have tried to change the firmware with odin. But fails every time
    02-20-2016 02:40 AM
  2. Tech-Newb's Avatar
    Are you sure the new battery is original and OEM?
    Can you post screenshots of tour battery usage stats? Does your phone heats up often?
    Posted with ❤Love❤
    02-20-2016 04:47 AM
  1. phone update Note 4
    By Jude526 in forum Samsung Galaxy Note 4
    Last Post: 02-21-2016, 10:36 AM
  2. Super bad battery life on lg g2
    Last Post: 02-20-2016, 04:49 AM
  3. Replies: 0
    Last Post: 02-20-2016, 12:40 AM
  4. Replies: 0
    Last Post: 02-19-2016, 11:38 PM
  5. Replies: 0
    Last Post: 02-19-2016, 10:55 PM
