How can I fix this display problem
  • Start date Start date
A
AC Question
A display problem has occured recently. When the brightness of the screen is set to minimum/very low, one side of the screen appears a little brighter and flickers, starting from the same side as the home button, it seems to get darker 1 bar at a time, until the display is consistently the minimum brightness. (without being able to post a screenshot i cant explain better)
I have tried starting in safe mode (however whats app was running and i thought no apps run in safe mode but the disable safe mode button was there to so idk) anyway the display problem was still present.
android version 5.0
Lelix2603
