1. AC Question's Avatar
    I've heard some people mention they've gone a whole day with heavy use on their note 3 but I can't seem to get the same on mine. I recently bought a note 3 and it came with kitkat 4.4.2 not jellybean. When i play a video on my note 3 with full brightness it loses battery at 15% an hour and when i dim it to lowest it drains at 8% an hour, I have rooted my phone and disabled any unwanted running apps and unchecked all gestures, gps and autosync options, but still unsure whether its the normal amount or is my battery defected? I had grand 2 previous to this note 3 version and it used to drain 10% battery an hour with heavy usage with auto brightness, and used to drain about 6% battery while playing videos with lowest brightness and those percentage were on 2600 mah battery compared to note 3's 3200 mah.
    Whenever i play a game on my note 3, battery seems to drain alarmingly, can't go more than 3 hours with heavy usage.
    I just want to know what's the average video playing time for note 3 as certain apps drain more than others so can't really compare via apps. So maybe comparing my note 3's battery life while playing videos with other note 3 users may give a better idea on my battery.
    02-26-2016 07:02 AM
  2. Golfdriver97's Avatar
    Welcome to the forums. Something to keep in mind is the screen is a lot bigger. Everyone's usage will always be different. How long have you had the Note?
    02-26-2016 09:21 AM
  1. What's going on with my battery?
    By onnad in forum Verizon LG G2
    Last Post: 03-02-2016, 06:16 PM
  2. Live wallpaper is not working [Note 5] - How do I fix it?
    By srinathp1988 in forum Samsung Galaxy Note 5
    Last Post: 03-01-2016, 06:16 PM
  3. Galaxy s6 tethering issues on Verizon Network
    By DieselRacer75 in forum Samsung Galaxy S6
    Last Post: 02-27-2016, 10:58 AM
  4. Replies: 6
    Last Post: 02-26-2016, 02:58 PM
  5. my note edge does not have any display, what can i do?
    By RR STAY in forum Ask a Question
    Last Post: 02-26-2016, 04:01 AM
