1. AC Question's Avatar
    My SD card keeps saying it's blank and unsupported how do I fix it n my settings it just started being using same one for a minute
    03-05-2016 12:23 PM
  2. itguyjax8430's Avatar
    Welcome to Android Central!
    Do you have anything on the card? If not you can go to your settings, storage, and format the card. This will erase the card and may fix it.
    03-05-2016 03:01 PM
  1. Moved apps to SD card, now having big problems
    By Not The Droid in forum Samsung Galaxy Note 4
    Last Post: 03-13-2016, 04:36 PM
  2. Replies: 1
    Last Post: 03-10-2016, 11:15 AM
  3. Why wont my galaxy E5 turn on?
    Last Post: 03-10-2016, 11:09 AM
  4. Replies: 1
    Last Post: 03-07-2016, 10:48 AM
