1. Sashaboy3's Avatar
    Today, I noticed my battery was going really fast (which means super fast because Nexus 5). I checked my battery log in the night, and I found that WiFi and Maps were using ~35% each. I never use Maps, and I had turned off WiFi every time I went out. I went to the larger graph, however, and it said WiFi had been on all day, and so had GPS. My GPS is always off. Also, I checked on Maps multiple tines, and tried to force stop, but it was grayed out, which I'm pretty sure means its not running. Any help?
    03-09-2016 09:45 PM
  2. Sashaboy3's Avatar
    Also this screenshot
    03-09-2016 09:46 PM
  3. Joshua Cheong Zu Hao's Avatar
    I have the exact same problem, only with GPS. WiFi is off all the time (mostly) so all the data drain is coming from Google Maps and the GPS which is perpetually on. Will somebody please help me (I mean, us)?
    03-31-2016 10:39 PM
  1. Camera/Gallery and SD card after Marshmallow update
    By atari52oo in forum Motorola Droid Turbo 2
    Last Post: 03-13-2016, 09:24 PM
  2. OneDrive and One Note on a Kindle (1st Gen) HELP!
    Last Post: 03-09-2016, 11:59 PM
  3. Why is my Note 4 crashing and restarting?
    Last Post: 03-09-2016, 11:20 PM
  4. Does the 4 and 6 use the same battery
    Last Post: 03-09-2016, 09:23 PM
  5. New phone protocol - Smart Switch and SD card
    By PsychDoc in forum Samsung Galaxy S7 edge
    Last Post: 03-09-2016, 08:41 PM
