1. BriniaSona's Avatar
    This is the bike mount I have now. http://www.iottie.com/Product/Detail/948/iOttie-Easy-One-Touch-Universal-Bike-Mount-Holder-for-iPhone-5S_-5C_-5-4S_-Smartphone It does not fit, with the phone plus it's case. And I do not want to remove the case while biking. It just feels too risky.
    I wish they would design these with cases in mind.
    03-11-2016 04:01 PM
  2. nahoku's Avatar
    The mount specs read - Fits mobile devices 2.1 inches to 2.9 inches wide
    The best I can offer is you measure the width of your phone (with case on) and look at the specs of the mounts you're interested in. I'm sure there must be something out there.
    EDIT... Here's one that goes from 2.25 inches to 3.25 inches wide. Link
    03-11-2016 06:36 PM
  1. Using fingerprint ID for apps
    By uawildcat in forum Samsung Galaxy S7 edge
    Last Post: 03-12-2016, 10:48 AM
  2. Best way to mirror to hotel tv (no ethernet available?
    Last Post: 03-12-2016, 12:50 AM
  3. Replies: 1
    Last Post: 03-11-2016, 07:53 PM
