1. AC Question's Avatar
    My phone died, so I plugged it into the charger and left it. I attempted to switch it back on and after multiple times it eventually switched on, only to find that it would switch off again after 5 minutes or so. I assumed it was because it wasn't charged enough. So I have been letting it charge and instead of the percentage increasing it has been decreasing whilst charging. I have turned off the wifi, Bluetooth etc. Any increase the charging gets, it drops rapidly once taken off the charger.
    03-13-2016 05:37 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which phone? It's possible the battery has failed. Can you try a new or different battery?
    03-13-2016 09:40 PM
  1. Google Opinion Rewards not working on the S7 Edge?
    By SprintFun in forum Samsung Galaxy S7 edge
    Last Post: 03-14-2016, 04:32 PM
  2. Where can I find the microphone settings for Samsung S4 Active ?
    By AC Question in forum Samsung Galaxy S4 Active
    Last Post: 03-13-2016, 09:27 PM
  3. My ALCATEL onetouch wont connect to wifi no matter what
    Last Post: 03-13-2016, 06:53 PM
  4. which android phone manufacturer can you trust?
    Last Post: 03-13-2016, 05:15 PM
  5. How to factory reset an encrypted phone
    Last Post: 03-13-2016, 05:11 PM
