1. AC Question's Avatar
    Hi,
    I did swipe the edge of darkened lock screen after previously turning edge feeds On, but I get no response, or I get a message saying " no new feeds". I've yet to get any feeds at all.
    What can I do to fix this?
    Thanks for any help you can offer, Carole
    03-14-2016 07:17 PM
  2. itguyjax8430's Avatar
    Hi,
    Welcome to Android Central!
    Are you just trying from the lock screen or does it not work when unlocked? Did you disable any Yahoo apps?
    03-14-2016 07:20 PM
  3. ruggedhunter's Avatar
    Your screen should be off, not on lockscreen. Do the swipe gesture. A clock/weather feed should appear. Swipe towards or away from the center of the screen to scroll thru the different feeds that you enabled in settings.
    03-15-2016 12:18 AM
  1. Replies: 1
    Last Post: 03-14-2016, 07:22 PM
  2. Samsung GS7 Edge Voice contol inside camera
    By DroidCoug in forum Samsung Galaxy S7 edge
    Last Post: 03-14-2016, 07:18 PM
  3. Samsung Galaxy S7 Wifi password Too Long to enter
    By shaneschantz in forum Samsung Galaxy S7
    Last Post: 03-14-2016, 07:00 PM
  4. Replies: 0
    Last Post: 03-14-2016, 06:58 PM
  5. My galaxy s 7 screen turned black and it hasnt turned back
    Last Post: 03-14-2016, 06:44 PM
