1. AC Question's Avatar
    I don't like having to use the power or home button too much, I just want to wave my hand over the phone to wake up.
    03-17-2016 10:18 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! I don't think the S7 edge has air gestures. You can use S Voice to wake the phone up--see pg 118 of the manual: http://downloadcenter.samsung.com/co...1.0_160219.pdf
    03-17-2016 11:32 AM
  3. tbstroken's Avatar
    I still use this sensors on my note 3 n900 on marshmallow port from s7 and note 5, Samsung should've kept them optionally
    06-07-2016 05:35 PM
  4. HTownTim's Avatar
    Are you saying you somehow activated Air view on your S7 using parts from an older phone? I would like to do it also if it can be done..
    07-31-2016 08:51 PM
  5. Numanji's Avatar
    This might be late reply for the question but might help anyone searching for the solution.
    Go to: Settings > Accessibility > Dexterity and interaction > Easy Screen turn on and toggle ON.
    You can now move your hand over the upper sensor to wake up your device without even touching your S7 Edge. Hope this is helpful. Thanks.
    08-18-2016 10:07 PM
  1. $200 off price on Dell Venue 8 7840 at the Dell store
    By Lance Holmes in forum Dell Venue 8 7000 Series
    Last Post: 06-09-2016, 11:48 AM
  2. how can I fix google play not working?
    Last Post: 03-17-2016, 11:34 AM
  3. Nexus 5X won't power on
    By Droidnought in forum Nexus 5X
    Last Post: 03-17-2016, 10:43 AM
  4. How to upgrade my android tablet to Android Lollipop ?
    By Developer10 in forum Android 5.0 Lollipop
    Last Post: 03-17-2016, 10:16 AM
