A AC Question Mar 18, 2016 #1 I am trying to connect to WiFi using a passcode. It keeps saying authentication problem. What do I do to fix it?
Golfdriver97 Trusted Member Team Leader Moderator Dec 4, 2012 35,367 113 63 Visit site Mar 18, 2016 #2 Welcome to the forums. Are you sure the password was entered correctly? If not, you can go into settings>wifi>and the connections should show. Longpress on the one you need, and you can click forget. This will allow you to reconnect to the router. Upvote 0 Downvote
