1. AC Question's Avatar
    I am trying to connect to WiFi using a passcode. It keeps saying authentication problem. What do I do to fix it?
    03-18-2016 07:50 AM
  2. Golfdriver97's Avatar
    Welcome to the forums. Are you sure the password was entered correctly? If not, you can go into settings>wifi>and the connections should show. Longpress on the one you need, and you can click forget. This will allow you to reconnect to the router.
    03-18-2016 09:26 AM
  1. Replies: 7
    Last Post: 03-19-2016, 04:19 PM
  2. Replies: 1
    Last Post: 03-18-2016, 09:40 AM
  3. Screen Lock Problems Galaxy S6
    Last Post: 03-18-2016, 06:39 AM
  4. Replies: 0
    Last Post: 03-18-2016, 06:35 AM
  5. Replies: 1
    Last Post: 03-18-2016, 06:31 AM
