1. AC Question's Avatar
    Definition
    03-19-2016 03:36 AM
  2. qwertypop13's Avatar
    Well, a hardware problem is when a computer component has a problem (e.g. you screen cracks or your processor is broken), where as a firmware problem is when a program (application) malfunctions and causes the computer to function incorrectly. A software problem is usually cheaper and easier to fix than a hardware problem. Hope this helps you, Dario.
    03-19-2016 04:13 AM
  1. Replies: 1
    Last Post: 03-19-2016, 08:45 AM
  2. Replies: 0
    Last Post: 03-19-2016, 03:30 AM
  3. Replies: 0
    Last Post: 03-19-2016, 02:44 AM
  4. google play store problem
    Last Post: 03-19-2016, 02:26 AM
  5. Why is Skype slow to load
    Last Post: 03-19-2016, 01:59 AM
