1. AC Question's Avatar
    So i just flashed the latest update for Prime 6 (130FFN2) through Sugar QCT SP 10.1 flash tool, now my battery drains super fast and the overall phone performance is very low.
    I can't run Facebook because it gets stuck at the facebook logo with a blue background (version 53.0 nodpi min. API 15), and the phone struggles to execute many apps at the same time (quad core 1Ghz processor Snapdragon 410).
    I really need help here, my phone is useless the way it is and I already cleaned cache and made factory reset many times, but still the same. The device now overheats which did not do before the update.
    I cant find any stock ROM for the phone unless the tool that I use to flash the stock ROM but when it finishes flashing it always installs the new update, which it seems to be broken.
    The keyboard is using 76% of the battery apparently and apps like Google Search use 60% of the memory, my battery now only lasts 4 hours and it used to last two days with regular use, PLEASE HELP ME!
    03-19-2016 11:40 AM
  2. itguyjax8430's Avatar
    Welcome to Android Central!
    I believe battery drain was a common issue with 5.0.2. It had to do with the WiFi causing issues I believe.
    03-22-2016 07:05 AM
  1. Replies: 2
    Last Post: 03-27-2016, 03:08 AM
  2. How to Wake on Lan from shutdown over 3G (mobile network)?
    Last Post: 03-22-2016, 06:59 AM
  3. how do i recover a pre-installed app on my blackberry 9320
    Last Post: 03-22-2016, 06:51 AM
  4. S7 Edge standby battery life?
    By Hock3y Monk3y29 in forum Samsung Galaxy S7 edge
    Last Post: 03-21-2016, 08:52 AM
  5. Replies: 1
    Last Post: 03-19-2016, 11:01 AM
