1. KrisciusP's Avatar
    Hi guys. I've encountered this issue with the sound on my s6 edge. It seems that it is not detecting my headphones. I've tried different ones, so the issue is in the phone itself. This happened randomly. Now I've noticed that the phone will actually play music through the headphones IF I plug them in and then reboot the phone. But in this case, the phone will not play music when the headphones are unplugged and through the speakers (however I can hear notification sounds through the speakers).. If I reboot the phone with the headphones unplugged, it will only play music through the speakers (even while the are plugged, doesn't matter). Any ideas? Software is 6.0.1
    03-19-2016 02:59 PM
  2. Armando Cabral's Avatar
    I had the same exact problem, uninstall the Samsung music update that came with marshmallow and reboot the phone. It worked for me.
    03-28-2016 06:52 PM
  1. Not getting gmail
    By scuba05477 in forum Samsung Galaxy S5
    Last Post: 03-20-2016, 09:23 PM
  2. Replies: 1
    Last Post: 03-19-2016, 04:44 PM
  3. Why is my phone so slow
  4. Replies: 0
    Last Post: 03-19-2016, 02:56 PM
  5. why is my htc m8 keep shutting down
