1. AC Question's Avatar
    Last night I dropped my phone in a bucket of water, and the phone continued to work (playing music in this case) when I took it out from bucket immediately.
    I dried off my phone with paper towels, and not knowing what actions to take besides that at that point of time, I though everything was fine and continued to use the phone. (it seemed fine since the phone was functioning normally, and because S4 active is supposed to be water-proof?).
    Then when I wanted to charge my phone, I realized it failed to charge. So I did some googling and found out that I should cover the phone with rice entirely, and so I did.
    This morning i woke up and uncovered my phone from the rice to see if that solved the issue. It didn't . . .
    My own instinct told me to clean the phone with some alcohol, since the water that my phone dropped in was not the cleanest water unfortunately. I specifically cleaned the usb/charging part of the phone with alot of alcohol and miracle happened ! It charged !!! I managed to charge my phone back up from 0% to 50% but now this miracle is gone when I turned on my phone, hoping to charge & use it at the same time.
    So can anyone tell me what exactly should I do with this phone ? I just listed everything that I did so far with the phone, did I screw up things more or what...?
    03-20-2016 04:28 PM
  2. anon(632115)'s Avatar
    Its not really possible to diagnose without physically examining the device. Water can cause components to short. The best thing to do is take it to a repair shop
    03-20-2016 04:40 PM
  1. Trade-in S4
    By wally9778 in forum Samsung Galaxy S7
    Last Post: 03-24-2016, 07:32 PM
  2. Replies: 2
    Last Post: 03-22-2016, 01:20 PM
  3. Can't register phone with Samsung
    By grafixguy#AC in forum Samsung Galaxy S7 edge
    Last Post: 03-21-2016, 06:54 PM
  4. Replies: 2
    Last Post: 03-21-2016, 04:37 PM
  5. LG G2 Microphone issue, please help
    By RKAYER in forum LG G2
    Last Post: 03-20-2016, 03:58 PM
