1. Rayhan Nugraha's Avatar
    I usually have 612mb free on my internal storage, when I start up my phone this morning, it gave me the notification "storage space running out" I don't know why and last night I was just playing Clash of Clans
    03-24-2016 11:21 PM
  2. mhinc's Avatar
    There could be so many reasons for this. First, what apps do you have running at all time?
    You could also grab an app like POWER CLEAN from the Play Store free to find unused files and clean them
    Just don't do the memory clean. Only the JUNK CLEAN. That alone will probably free up at least 500MB
    03-25-2016 03:36 AM
  3. AlphaTango414's Avatar
    Like mentioned above, many possibilities. My bet will be app updates.
    mhinc likes this.
    03-25-2016 04:06 AM
  4. Rayhan Nugraha's Avatar
    You could also grab an app like POWER CLEAN from the Play Store free to find unused files and clean them.
    Okay, I'll try that but the problem is, it's from the play store. To install apps, at least you must have 506mb right? Currently, I only have 377mb free
    03-25-2016 07:25 AM
  5. Rayhan Nugraha's Avatar
    Hey, just found something HUGE.
    Attached Thumbnails Need Help! My phone's internal storage dropped overnight.-261378.jpg
    03-25-2016 07:33 AM
  6. mhinc's Avatar
    114MB is by no means huge. Not even close compared to some games. I would be going through all your installed apps and uninstalling anything you don't need. And then running Power Clean to clean up the rest of the junk that's there that you don't need.
    Do you play Clash Royale? If not maybe remove it and anything else in your installed apps that you don't use.
    Rayhan Nugraha likes this.
    03-25-2016 07:57 AM
  7. Rayhan Nugraha's Avatar
    What I mean is the Cache, look at it. Remember to breathe this time.
    03-25-2016 08:00 AM
  8. Rayhan Nugraha's Avatar
    Well, I have somethin' like that. Clean Master, it can't be deleted cuz I'm not rooted and it's a bloatware from ASUS
    03-25-2016 08:14 AM
  9. mhinc's Avatar
    If you want help, it's probably a good idea not to mach people.
    You haven't actually given any phone specs. I am assuming you are running at least a 16GB phone. Looks like you have a Micro SD Card as well.
    I am wondering how one could actually fill 16GB plus have an SD Card, and not be able to clean SOME of the stuff off. Pics? Videos? Etc...
    Now take a breath, and remove all the crap on your phone if you want space.
    03-25-2016 08:16 AM
  10. Rayhan Nugraha's Avatar
    Oh yeah, sorry. I have an ASUS Zenfone 5 8GB ROM, 2GB RAM, with a 8GB Sandisk MICROSD card. That's enough, I think
    03-25-2016 08:21 AM
  1. Replies: 1
    Last Post: 03-28-2016, 07:38 AM
  2. Renaming my android device thru Terminal emulator
    By AC Question in forum Android 4.4 KitKat
    Last Post: 03-28-2016, 07:36 AM
  3. Replies: 1
    Last Post: 03-28-2016, 07:29 AM
  4. How do I get someone to text me back on my phone?
    Last Post: 03-25-2016, 12:53 AM
  5. How can I rename my Insignia Android device?
    By rameshjey in forum Android 4.4 KitKat
    Last Post: 03-24-2016, 11:14 PM
