1. AC Question's Avatar
    Does anyone has Issue with the colour of the led notification? My WhatsApp is set to white but notification it's always blinking purple. I tried changing to cyan and it's blinking blue. Help anyone...? Other than downloading app manager...
    03-25-2016 10:17 AM
  2. itguyjax8430's Avatar
    Welcome to Android Central!
    You might need to use an app like Light Flow to fix the colors.
    03-28-2016 08:12 AM
  3. Alex Tavares's Avatar
    I've noticed that but i'm not sure if its a problem. The white color is made up of the red, green and blue LEDs lit up at the same time, so probably that's why we're seeing a purplish color. I'm not sure how it works exactly and if it's possible to control the intensity of each LED, but if so, an update from Samsung should fix it.
    04-10-2016 09:11 AM
  1. Samsung Galaxy Edge S7 does not fit in Samsung Gear HR
    Last Post: 03-28-2016, 08:06 AM
  2. Note 3 vs S7 Edge
    By Scorpiouno in forum Samsung Galaxy Note 3
    Last Post: 03-26-2016, 05:05 PM
  3. Replies: 1
    Last Post: 03-25-2016, 12:05 PM
  4. Replies: 1
    Last Post: 03-25-2016, 09:59 AM
  5. Replies: 4
    Last Post: 03-25-2016, 09:54 AM
