1. Sandipann's Avatar
    I have galaxy J7. Its software is 5.1.1. But it doesn't contain any optiom to turn on the key lights. Pls help me.
    03-26-2016 01:39 PM
  2. itguyjax8430's Avatar
    Welcome to Android Central!
    Give this app below a try, it should do what you want. I believe Samsung removed the ability to turn them off in the newer phones.
    https://play.google.com/store/apps/d...onlights&hl=en
    03-31-2016 11:40 AM
  1. problem installing RBS banking app
    By DarrenHealy in forum Samsung Galaxy S7
    Last Post: 03-27-2016, 06:59 AM
  2. 360 Software Update Problems
    By gmeyer8 in forum Moto 360 (2015)
    Last Post: 03-26-2016, 12:45 PM
  3. Galaxy S6 SYNC Problems
    By bradkusik in forum Samsung Galaxy S6
    Last Post: 03-26-2016, 09:52 AM
  4. Exchange Active Sync & Calendar problems
    By uawildcat in forum Samsung Galaxy S7 edge
    Last Post: 03-25-2016, 05:21 PM
  5. Battery problem on Kyocera Hydra
    Last Post: 03-25-2016, 03:13 PM
