1. AC Question's Avatar
    How do I adjust the volume so that I can hear the caller better on samsung galaxy 3
    03-27-2016 05:48 PM
  2. nahoku's Avatar
    Use the volume switch on the side of the phone... or pull down the notification shade, long press on the "Sound" icon, and it'll take you to where you can adjust the volume.
    I know that was too easy an answer, so maybe you need to explain a little more about why you can't hear the caller.
    B. Diddy likes this.
    03-27-2016 10:15 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! If you're on a call, make sure you take the phone away from your ear first before adjusting the volume. Most phones lock the volume control when the phone is up against your ear.
    03-27-2016 10:54 PM
  1. Replies: 17
    Last Post: 04-15-2017, 09:10 AM
  2. how do i retrieve deleated clipboard txt
    Last Post: 03-27-2016, 10:57 PM
  3. ee firmware for wifi calling
    By Alex Withington in forum Android 6.0 Marshmallow
    Last Post: 03-27-2016, 05:33 PM
  4. Replies: 0
    Last Post: 03-27-2016, 05:23 PM
  5. Replies: 0
