1. AC Question's Avatar
    I can not put my passcode in, the screen won't work. I can double tap to turn it on, answer calls and draw with quick note, but nothing else will work! It won't even let me turn it off or restart. I really don't want to factory reset because I'll lose everything on there. Please help!
    03-27-2016 10:48 PM
  2. belodion's Avatar
    If the battery is removable, take it out for a few minutes, then replace. Worth a try.
    03-28-2016 06:28 AM
  1. Lg G5
    By Rckfsh69 in forum LG G5
    Last Post: 03-28-2016, 08:12 AM
  2. Phone recommendations for my son and me?
    Last Post: 03-28-2016, 04:33 AM
  3. What is causing my Tab to erase it's apps after it crashes?
    Last Post: 03-27-2016, 10:32 PM
  4. how can i get music off my i pod touch to my android?
    Last Post: 03-27-2016, 10:20 PM
  5. Can't export all of the device contacts
    Last Post: 03-27-2016, 10:05 PM
