1. AC Question's Avatar
    Most power banks comes with li-ion or polymer cells with a rated voltage of 3.7V.
    The standard input voltage of smart devices is 5V so power banks need an output of 5V to charge smart devices.
    If I want to figure out how many times a 5000mAh rated power bank(lets assume that power bank really have that capacity) can charge my xiaomi mi4 (3080 mAh ) what calculation do I need to make?
    For example do I use the following calculation or i need to do something differently?
    5000mAh*3.7V=18.5Wh
    18.5Wh/5V=3.7Ah=3700mAh
    3700*0.9=3330mAh
    3330*0.9=2997mAh
    so 2997mAh/3080mAh=0.97 time
    in first time 0.9 means 10% loss from boost converter in the power bank and second 0.9 means 10% loss from smartphone circuitry.
    03-28-2016 04:42 PM
  2. H3aTeRzz's Avatar
    Hi & Welcome to the Android Central Forums!
    Hope this helps!
    https://www.quora.com/Power-Banks-1/...ge-an-iPhone-6
    Don't forget to register with us, its free & easy!!
    Chris
    03-28-2016 05:46 PM
  1. Which budget phone should I buy?
    By rnznco in forum Ask a Question
    Last Post: 03-28-2016, 07:19 PM
  2. How to remove extra home screens from Trio AXS4G Tablet 4.2.2
    Last Post: 03-28-2016, 04:34 PM
  3. Replies: 0
    Last Post: 03-28-2016, 04:12 PM
  4. How to fix ER081?
    Last Post: 03-28-2016, 04:09 PM
  5. How to fix ER081?
    Last Post: 03-28-2016, 04:08 PM
