1. AC Question's Avatar
    I have a Samsung Note 5 and a Gear S
    Paired successful
    After updating to Marshmallow when I go out of Bluetooth range and come back it won't connect automatically.
    I cleared cache. Unpaired and paired again and restarted.
    Didn't help
    Any idea?
    03-29-2016 07:18 AM
  2. H3aTeRzz's Avatar
    Hello, & Welcome to Android Forums!
    Sorry you've experienced this issue, and I'm sure you're only joining many others, with issues after the MM update. 2 things I recommend, hopefully the first one works.
    1. Enter Recovery, and Wipe Partition Cache.
    2.. Full Factory Reset - I know, not what you want to hear, see below.
    There are many folks who have no issues after a major update like MM; however there are an equal amount, in my opinion that suffer issues after these updates. I, as a rule, ALWAYS perform a Factory Reset after a major update, no exceptions. Just save yourself some headache and do it. BE SURE TO BACK UP YOUR PHONE USING SMART SWITCH OR EQUIVALENT.
    Hope this helps!
    Chris
    03-29-2016 08:41 AM
  3. Cloud182's Avatar
    Same here running 5.1.1. Keeps dropping with gear s but ok with car audio, bt speakers, bt earpiece. Gear s is now useless. Seems kind of a marketing strategy.
    03-29-2016 01:03 PM
  1. Replies: 2
    Last Post: 04-10-2016, 11:32 AM
  2. Showing UNKNOWN number on incoming calls in xolo phone
    Last Post: 03-29-2016, 03:22 PM
  3. Galaxy S6 Messages Error after Marshmallow Update - HELP!
    By Matthew Osborn in forum Ask a Question
    Last Post: 03-29-2016, 03:21 PM
  4. Root and TWRP V20d
    By sheppy1 in forum LG G4
    Last Post: 03-29-2016, 06:59 AM
  5. Please help thinking of buying new note 5
    By stsullivan in forum Samsung Galaxy Note 5
    Last Post: 03-29-2016, 06:45 AM
