1. AC Question's Avatar
    Android system is expired on my galaxy note y. This problem is keeping from using some applications and I can not use my browser. How I can I fix this problem
    03-29-2016 03:33 PM
  2. anon(632115)'s Avatar
    That is some popup wanting to install malware on your device. Don't go to any links. Try clearing your browser cache. If that doesn't work install and run anti malwarebytes. If that fails you will need to do a factory reset or flashing fresh firmware to your device
    03-29-2016 04:16 PM
  3. H3aTeRzz's Avatar
    Try this: goto>System> Device>Applications> application manager> scroll over to "All"> scroll down to the internet app called "Internet"> then select clear cache, and cleared data. Reboot and see if the problem persists. If that doesn't work, and the Malwarebytes doesn't work, I would suggest a full factory reset, be sure to back up all of your data.
    Laura Knotek likes this.
    03-29-2016 09:36 PM
  1. Replies: 8
    Last Post: 03-03-2017, 02:24 AM
  2. Preorder from ATT has shipped!
    By deviceid in forum LG Watch Urbane 2nd Edition
    Last Post: 03-30-2016, 06:59 PM
  3. How do I restore haptic feedback?
    By mocris in forum Samsung Galaxy Ace
    Last Post: 03-30-2016, 04:39 PM
  4. [ZTE Obsidian] How to get a zte phone to lauch an app in default
    By AC Question in forum Other ZTE Android Phones
    Last Post: 03-30-2016, 04:28 PM
  5. Replies: 1
    Last Post: 03-30-2016, 04:19 PM
