1. AC Question's Avatar
    Basicly I updated my galaxy s6 since then some of my apps won't work iv tried everything I can think of my snapchat doesn't refresh and my Facebook has connection issues which are all new any help resolving this as I have tried delete and re downloading restart device problems Started since I updated the fones software version these are some of the problems to name a few more it on lying affects apps that need service which my I telnet is fine and working please help me
    03-31-2016 06:34 PM
  2. H3aTeRzz's Avatar
    Hi and welcome to Android Central forums!
    If you are referring to the recent marshmallow update, you're joining a lot of people with issues like you just described.
    You can try going into recovery, and wiping the system cache partition. This will not delete any data.
    You can go to YouTube and search for, enter recovery on Galaxy S6, and you will find some pretty informative videos on how to do that.
    There are some that will argue with my next statement, but I do a full factory reset after every major update. There are many who don't have issues, but here lately it seems like a lot of folks are having issues after these major update.
    Let us know if the cache partition wipe doesn't work, and we'll go on to the next step. Hope this works!
    03-31-2016 08:25 PM
  3. H3aTeRzz's Avatar
    Please do not do a full factory reset, without first properly backing up your phone's pictures contact data and so on. If you choose to do that route we can provide you with some informational videos on how to back up all of your phones important data and photos.
    03-31-2016 08:28 PM
  1. Replies: 6
    Last Post: 07-17-2016, 09:27 PM
  2. Need some help; screen issue
    By doctordwaynewilliams in forum Google Nexus 6
    Last Post: 04-01-2016, 01:03 PM
  3. Replies: 1
    Last Post: 04-01-2016, 07:11 AM
  4. Replies: 1
    Last Post: 03-31-2016, 09:34 PM
  5. help with installed but nowhere-to-be-found app?
    Last Post: 03-31-2016, 05:25 PM
