You will have to take it to your nearest mobile phone repair center. If it's just the charging port that's damaged, then I don't think it will be expensive. Another solution is to buy a battery charger. You can then simply remove the battery and then charge it separately. ASUS store sells both the battery and battery charger for $29.99 that's about 1382 philippine peso.
