1. AC Question's Avatar
    My galaxy 3 turns off without pressing the power button nor chossing to do so and the power button is too sensitive
    04-03-2016 02:32 PM
  2. belodion's Avatar
    It may be a fault in the power switch under the button. I guess you'd have replace it if that were the case. Cleaning the button with alcohol, just enough to run down under it, might help.
    04-03-2016 02:39 PM
  3. trclark81's Avatar
    Since this is 4 months old I'm not sure if anyone's even still looking at it. I have the same issue with an LG phone. Not much you can do to truly fix it so far as I can tell, but you can make it slightly less annoying. Here's what you do. Buy yourself a cheapo gel case (we're talking bargain basement here). Most of these come with a sort of textured cover over the buttons. Sometimes that's all you need to do. The covers deaden the response enough. If not, take a pair of scissors (here's the reason you buy a cheap one) and cut off the button cover over the power button. That makes a small hole over the button. It shouldn't be a deep enough hole that you can't still turn the phone on and off, but it's now deep enough that just sliding it in a pocket should no longer turn it on/off. It's a hack, sure, but if you don't get free replacement for your phone it's a heck of a lot cheaper than buying a new phone to replace the perfectly functional one you already have.
    08-18-2016 08:22 PM
  1. Please help unbrick my Nexus 10
    By arjen82 in forum Google Nexus 10 Tablet
    Last Post: 04-13-2016, 08:45 AM
  2. Is The Samsung Smart Manager Efficient and Sufficient?
    By pixel_junkie in forum Samsung Galaxy S7
    Last Post: 04-03-2016, 09:46 PM
  3. Replies: 6
    Last Post: 04-03-2016, 05:04 PM
  4. How do I get smart mode or safe mode of my tablet?
    Last Post: 04-03-2016, 02:44 PM
  5. Is it possible to root the htc desire 520?
    Last Post: 04-03-2016, 02:13 PM
