1. AC Question's Avatar
    I bought a Samsung Galaxy J5 yesterday, and I've already filled the internal storage with music, photos and apps, so I found an old SD card around the house (Samsung 8GB MicroSD) and put it in, but it says it's blank and may contain an unsupported file? If I click on the notification it says erasing SD Card, I don't mind that it's being wiped, but it doesn't do anything after? I'll then go into settings and into storage to click "mount SD" but it says "Please Insert A Sim Card" whilst I have a notification saying "Sim Card Safe to Remove"
    Please help?!
    04-03-2016 02:41 PM
  2. sydneycooper1979's Avatar
    Is there an option to format it? If not, you may just need to get a new sd card
    04-03-2016 02:48 PM
  1. File on MicroSD card are read only
    By jpintn in forum Samsung Galaxy Tab A (8 & 9.7)
    Last Post: 01-23-2017, 01:56 PM
  2. Replies: 2
    Last Post: 08-18-2016, 08:22 PM
  3. Texting small video from SD Card
    By lsmith9523 in forum Samsung Galaxy S7 edge
    Last Post: 04-04-2016, 11:57 AM
  4. Replies: 1
    Last Post: 04-03-2016, 02:51 PM
  5. Replies: 9
    Last Post: 04-03-2016, 11:34 AM
