1. Dex Rivera's Avatar
    I have problem with my samsung note 4 battery draining fast since i download the new software lollipop. How do i fix to dont drain my battery fast?
    04-04-2016 01:00 PM
  2. belodion's Avatar
    Welcome.
    Try a Cache Partition wipe after a software upgrade. If it does no good, it will at least, so far as I know, do no harm.
    If no go, the stronger medicine of a Backup & Reset can be applied. Let us know if you need advice about that, especially the backing up.
    H3aTeRzz likes this.
    04-04-2016 02:03 PM
  3. Dex Rivera's Avatar
    how you clear the cache partition?
    04-05-2016 09:25 PM
  4. H3aTeRzz's Avatar
    Use the volume down button to select wipe cache partition. This will not delete any data.
    Attached Thumbnails my samsung note 4 is draining  battery fast-1459910118406.jpg
    04-05-2016 09:35 PM
  5. Dex Rivera's Avatar
    still not doing good on my battery life? what should i do? i just got new battery.
    04-05-2016 09:51 PM
  6. H3aTeRzz's Avatar
    Okay, you probably not going to want to hear this, as it is always a last resort. Sometimes after a major software update like you have performed, it does require a full factory reset, as it is what it is, sometimes bugs appear as a result of these new updates.
    It is not as bad as it used to be, as there are wonderful programs out there that can backup your entire phone including all contents. 2 apps for an example would be smart switch by Samsung, and helium. Both available in the Play Store.
    Even though those two programs are great apps, I would still recommend connecting your sync cable to the computer with your phone attached and transfer all of your important photos over to your computer first before you start that process.
    Good luck my friend, I hope all works out, please let us know!
    Chris
    04-06-2016 06:10 AM
  7. Dex Rivera's Avatar
    is that the way to resolve this draining problem?
    04-06-2016 09:15 PM
  8. H3aTeRzz's Avatar
    Well I can make no promises, that it will. But I will say that, a majority of those, that had issues after a major update, were solved only by doing a full reset. Some actually were solved after the Cache Wipe, in your case, it didn't help. The only other thing you can try, is to purchase a new Original Battery, and try it...to rule out the possibility that the battery itself is the issues.
    Hope this helps!
    Chris
    04-06-2016 10:48 PM
  9. Dex Rivera's Avatar
    i just get my new battery note 4 do i need to drain the new battery or i go straight charge for how many hours?
    04-08-2016 05:33 PM
  1. How can I get my Note 4 working?
    By Primo Myth in forum Samsung Galaxy Note 4
    Last Post: 04-04-2016, 04:14 PM
  2. i cant open my phone settings and certain apps
    Last Post: 04-04-2016, 02:13 PM
  3. Replies: 0
    Last Post: 04-04-2016, 12:58 PM
  4. Replies: 0
    Last Post: 04-04-2016, 12:48 PM
  5. Is anyone else having problems with the group messages?
    Last Post: 04-04-2016, 12:45 PM
