1. AC Question's Avatar
    Since a week or so my battery is draining much faster(at the end of the day 30-40% should be remaining but now it is empty at the end of the day). Also, I think this might be the cause, often when i unlock my phone it says "Bluetooth was stopped(not sure what it is in English)". On top of that my phone is not connencted to W-Lan when locked so when i unlock it, it connects with the W-Lan even though it should alredy be connected.
    04-06-2016 10:31 AM
  2. itguyjax8430's Avatar
    Welcome to Android Central!
    Are you using a bluetooth device on your phone or do you just leave it on?
    04-11-2016 07:48 AM
  3. Rukbat's Avatar
    Also, you're probably allowing W-Lan to sleep when the phone does, That turns W-Lan (Wifi) off when the screen goes to sleep, so it should save some battery, but you'll miss notifications that only come in via wifi.
    04-13-2016 10:35 AM
  1. Replies: 1
    Last Post: 04-11-2016, 07:46 AM
  2. Replies: 1
    Last Post: 04-11-2016, 07:42 AM
  3. Replies: 1
    Last Post: 04-06-2016, 10:20 AM
