1. AC Question's Avatar
    sometimes it turns off on its own and reboot again. when i inset earphone it automatically adjust volume to zero
    04-09-2016 07:02 AM
  2. H3aTeRzz's Avatar
    Hi
    Sounds like your volume rocker is malfunctioning. If you've exposed it to a fall, or liquid damage, that could be the result. You can check to see if its software related, but trying a Cache Partition Wipe through the Recovery Mode; don't think that's it, but worth a try!
    Google> "How to enter Recovery Mode on "your phone model here."
    A trip to a repair facility might be in order. Changing the volume rocker should be relatively easy and inexpensive.
    Hope this helps!
    Chris
    04-09-2016 08:17 AM
  1. Unlock Verizon Galaxy S7 Edge to T Mobile
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 02-27-2017, 05:59 PM
  2. Replies: 1
    Last Post: 04-10-2016, 07:13 PM
  3. Water logged galaxy s6 with triangle and red thermometer
    Last Post: 04-09-2016, 08:19 AM
  4. I have lost the date/time and weather on my screen
    Last Post: 04-09-2016, 04:10 AM
  5. Samsung Ace4lte home key not working
    Last Post: 04-09-2016, 04:08 AM
