1. AC Question's Avatar
    phone is samsung galaxy s4 sgh-i337 AT&T. i DONT HAVE PHONE IN PERSON. will the red led lite up if charging port is good but the phone wont power up. also will battery icon show without phone powering up or must the phone be able to power up for these functions to work.THANKYOU.
    04-11-2016 12:16 PM
  2. H3aTeRzz's Avatar
    Hi and welcome to Android Central forums! When you plug your device into a wall outlet, does any light come on? Does the vibrate motor vibrate?
    04-11-2016 01:11 PM
  3. helikvar's Avatar
    I have asked the owner to try plugging in the charger to see what happens and will get back to you as soon as I can with the answer to your question.thanks
    04-11-2016 02:46 PM
  4. helikvar's Avatar
    ok the red light does not come on and it does not vibrate.
    04-11-2016 03:26 PM
  5. helikvar's Avatar
    No lites ,no vibration, no signs of life .sorry if I doubled posted but I didnt see my previous reply.
    04-11-2016 03:34 PM
  6. H3aTeRzz's Avatar
    Hi helikvar!
    Sorry it took so long to get back to you!!
    I would recommend trying another battery out first. Since you have "no signs of life" the battery might be the issue. You also try another "compatible" cable and wall charger....it could very well be that the cable or box is bad.
    Hope this helps!
    Chris
    04-11-2016 06:29 PM
  1. LG G5se? What is LG upto?
    By Rizwan Basir in forum LG G5
    Last Post: 04-12-2016, 05:19 AM
  2. Replies: 1
    Last Post: 04-11-2016, 12:16 PM
  3. Text to Speech On Sony Smartwatch3
    Last Post: 04-11-2016, 12:08 PM
  4. Lenovo Tab 2 A10 won't write to SD card
    Last Post: 04-11-2016, 12:06 PM
  5. emails showing up on my Samsung galaxy s4 phone 2x
    Last Post: 04-11-2016, 11:55 AM
