1. AC Question's Avatar
    My Android Galaxy Note 3 will NOT charge. I have it plugged in, it won't connect to the charger and won't charge. It seriously just stays the same. It is not the wall seeing as how my laptop charges perfectly, so I am seriously confused. Here's the kicker... when I plugged it in at 11, IT WAS CHARGING JUST FINE! I need help. Especially since my phone is my only way to stay in contact with my family.
    04-13-2016 05:21 AM
  2. belodion's Avatar
    First, check that the USB port connector is clean and undamaged.
    04-13-2016 05:25 AM
  3. Zoe Harris's Avatar
    How do I do this exactly?
    04-13-2016 07:29 AM
  4. Rukbat's Avatar
    With a strong light and a strong magnifying glass.
    Also try the charger in another phone. It might have gone bad during the night. And try your charger in a different phone. (If that works, it points to a bad port in your phone.) And if it has a detachable cable, try a different cable.
    04-13-2016 09:08 AM
  5. MoonWillow9's Avatar
    I bought a new charger ..it worked great at first .Now I have to stand on my head , hold my mouth just right and pray the planets are in alignment to get my phone to charge.. This was happening before I bought the new charger.. What can I do?
    05-22-2016 09:14 AM
  6. belodion's Avatar
    Try a different USB lead, and make sure that the USB port connector is clean and undamaged.
    05-22-2016 10:05 AM
  7. MoonWillow9's Avatar
    On the chance of sounding ignorant what is a USB lead?
    05-22-2016 11:05 AM
  8. B. Diddy's Avatar
    He means to try a different USB cable.
    05-22-2016 04:38 PM
  1. Replies: 4
    Last Post: 04-14-2016, 08:30 AM
  2. Some questions about the Gear S2 I just received
    By PsychDoc in forum Samsung Galaxy S7 edge
    Last Post: 04-13-2016, 10:44 AM
  3. my moto x play is heating during in use
    Last Post: 04-13-2016, 05:27 AM
  4. Why is my Moto X Play heating during in use?
    By AC Question in forum Moto X Play
    Last Post: 04-13-2016, 05:26 AM
  5. Can I use a Fitbit one with my Elite?
    By AC Question in forum Fitbit
    Last Post: 04-13-2016, 04:33 AM
