1. AC Question's Avatar
    I have an unlocked Nexus 6 and I'm having connectivity issues.
    The following show emergency calls only then it shows no service then they go back and forth between those two then it shows LTE then it disappears for a long time?
    What should I do I try resetting the phone and that did not work.
    04-14-2016 04:41 PM
  2. itguyjax8430's Avatar
    Welcome to Android Central!
    Did you sent up the APN for MetroPCS on the Nexus 6?
    https://bestmvno.com/apn-settings/me...-apn-settings/
    04-18-2016 07:11 AM
  1. Why cant i get touchwiz 6.0 dark on my note5
    Last Post: 06-06-2016, 01:52 PM
  2. Is there a way to copy notes from Nexus 5 to Surface tablet?
    Last Post: 04-18-2016, 07:00 AM
  3. Why can I not save to my SD card from text message pictures?
    Last Post: 04-18-2016, 06:59 AM
  4. Where can I pre-order an unlocked HTC 10?
    By AC Question in forum HTC 10
    Last Post: 04-14-2016, 04:55 PM
  5. What is the size of the screen on the HTC 10?
    Last Post: 04-14-2016, 04:45 PM
