1. AC Question's Avatar
    Nexus seven powered down with 2% power left. Next time I try to power up plugged in, the machine would not charge.
    I've tried various combinations of a button pressing but nothing acts as advertised.
    04-18-2016 10:50 AM
  2. H3aTeRzz's Avatar
    Hi
    be sure you are using the Original Charger for your device.
    04-18-2016 11:08 AM
  3. Rukbat's Avatar
    1. At 2%, the battery probably has to be precharged. If the stock charger doesn't do precharge (most of them don't), the battery has to come out and be connected to a charger that does precharge.
    2. You should never drop a lithium battery below 40%. Only high-discharge lithium batteries are made to take that kind of use. (And you won't find any in cellphones - they cost more for the battery than a flagship cellphone costs.)
    H3aTeRzz likes this.
    04-19-2016 12:33 AM
  1. Display color irregularity
    By JovHok in forum Samsung Galaxy S7
    Last Post: 04-27-2016, 11:45 AM
  2. Unfortunately S note has stopped working. On S6 edge plus
    By Joeboy22 in forum Samsung Galaxy S6 edge+
    Last Post: 04-24-2016, 08:29 AM
  3. Huawei Watch - Buzzing for no reason?
    By PookiePrancer in forum Huawei Watch
    Last Post: 04-19-2016, 10:10 PM
  4. Replies: 2
    Last Post: 04-19-2016, 12:31 AM
  5. What happened to mic icon after update on sasmsung galaxy s6
    Last Post: 04-18-2016, 05:53 PM
