1. Pburton33's Avatar
    Volume is set to high. In settings > sounds and notifications > ring volume appears to be set to 0 but there is no way to change it.
    Oops, I found the answer. For that particular setting, you use the outside volume buttons to set the ring volume rather than the slide controls on the settings page.
    04-19-2016 02:41 PM
  2. sydneycooper1979's Avatar
    Oh good! Glad you found it!
    04-19-2016 02:58 PM
  1. Replies: 1
    Last Post: 04-19-2016, 06:41 PM
  2. Galaxy S6 - Cant find my downloaded music
    Last Post: 04-19-2016, 03:03 PM
  3. Replies: 0
    Last Post: 04-19-2016, 01:35 PM
  4. Replies: 0
    Last Post: 04-19-2016, 01:33 PM
  5. Where are my photos gone?
    Last Post: 04-19-2016, 01:31 PM
