1. AC Question's Avatar
    Mytouch4g, new battery, charger plugged in, strong constant amber light, hit power button, it made about 4 unh, unh unh sounds like a computer error message. Had this happen just as old battery failed, it humped in middle, would not hold charge. Cpu.? Bios? Will not power on.
    04-20-2016 12:53 AM
  2. Laura Knotek's Avatar
    It sounds like the bad battery damaged other parts in the device. The only way to know for sure what got damaged is if you take it to a local repair shop and have them take a look at it.
    04-20-2016 12:57 AM
  1. Replies: 12
    Last Post: 01-23-2017, 10:25 AM
  2. Wont make calls
    Last Post: 04-20-2016, 12:51 AM
  3. Can i root metro pcs kyocera hydro wave on lollipop 5.1
    By Kiddh88er in forum Software Development and Hacking
    Last Post: 04-20-2016, 12:15 AM
  4. Where is my antenna at on a lg tribute 2
    Last Post: 04-19-2016, 11:33 PM
  5. Night clock is gone with new update?
    Last Post: 04-19-2016, 11:20 PM
