1. Michael Lantz2's Avatar
    I have a Sony Xperia Z1s. It turns on screen looks fine but the screen will not respond to any touches whatsoever. I want to factory reset it but u have to use the touchscreen to do a full factory reset. I checked and the only reset available using only hardware buttons is a regular shutdown or a restart but no factory reset. If anyone out there knows how to fix the touchscreen or factory reset it without using the screen. Is there a way to initiate a factory reset using the USB connection? Any help at all will be greatly appreciated. Thanks.
    04-21-2016 10:30 AM
  2. itguyjax8430's Avatar
    Welcome to Android Central!
    You can try booting in to recovery mode and resetting through that menu. You will not need to touch the screen to do that.
    https://support.t-mobile.com/docs/DOC-9904
    04-25-2016 07:30 AM
  1. Samsung Tab S Overheating Problems
    By Team Sts in forum Samsung Galaxy Tab S 10.5
    Last Post: 09-04-2016, 08:37 PM
  2. Can I get some help with a problem that I am having with music apps?
    By MusicMagsandWax in forum Samsung Galaxy S7 edge
    Last Post: 04-26-2016, 04:30 PM
  3. Replies: 2
    Last Post: 04-21-2016, 02:03 PM
  4. Big google connection problem will Reinstalling android help??
    By Nirgranth in forum Android 4.4 KitKat
    Last Post: 04-21-2016, 12:08 PM
  5. LG G3 Stuck on on "Optimizing app" how to reset?
    By AC Question in forum LG G3
    Last Post: 04-21-2016, 07:41 AM
