1. AC Question's Avatar
    While plugged in the car the phone will only charge if I am using it. If the phone is not in use and plugged in, the battery drains.
    04-21-2016 03:07 PM
  2. Rukbat's Avatar
    If it only happens in the car and not in the house, I'd strongly suspect the car charger or the cable you use with it.
    04-21-2016 04:33 PM
  3. Dom82nd's Avatar
    Rukbat, thanks for your time and help. Thought that might work and tried a different charger and cable prior to my inquiry. Will also not charge if plugged in a computer. However will charge if the phone is in use. While typing this, the battery power increased 3%. But, as soon as I stop using the phone, the battery will not charge.
    04-21-2016 05:48 PM
  1. If and when MM for AT&T Note 5 your experience.
    By Rmbrown1964 in forum Samsung Galaxy Note 5
    Last Post: 04-25-2016, 08:27 PM
  2. stuck in android is starting
    By hammad1 in forum HTC One M9
    Last Post: 04-22-2016, 01:30 AM
  3. 'Print' makes the print screen crash?
    By Deakon67 in forum Samsung Galaxy S7 edge
    Last Post: 04-21-2016, 11:30 PM
  4. New to the SD card due to being with Apple. Need help.
    By seeyaiphone71 in forum Samsung Galaxy S7
    Last Post: 04-21-2016, 08:14 PM
  5. Does my phone have a virus?
    By bs61116 in forum Ask a Question
    Last Post: 04-21-2016, 04:35 PM
