1. AC Question's Avatar
    I bought a new Samsung s7 for Straight Talk, ATT
    I put my card in changed the settings and it worked ok for month
    NOW, it won't let me send picture messaging and upload pictures to any app, facebook, instagram, etc.
    I did a speed test and it said I have download date but Zero upload data.
    Straight Talk gave me different settings, a new sim card but nothing worked.
    I just exchanged my phone for a NEW phone and it still doesn't work.
    Are there some NEW settings for Samsung Galaxy S7
    04-21-2016 04:51 PM
  2. DEman19901's Avatar
    I have and S7 Edge and I am experiencing the exact same problems. I also ordered a new SIM and has the same results. If I turn off wifi and clear my apn setting,reboot and reenter APN settings it will begin working again for a brief period. Then for whatever reason, it goes back to not working again.
    04-22-2016 05:22 PM
  3. Lyndalinda23's Avatar
    Change the bearer setting to "LTE" that let mi send mms and check apps away from WiFi
    04-28-2016 05:43 AM
  4. PhoneyBaloney's Avatar
    I changed the Bearer to LTE and it didn't do anything?????
    I can receive data but not send data.
    04-29-2016 11:09 PM
  5. getwidit's Avatar
    im getting the same problems also. no idea what todo, my 650 dollar phone wont upload. Thinking about trying ATT go phone when my plan runs up on the 5th. SAME ISSUES change apn works a day or two and then back to no upload. When i switched bearer to lte i lost all connection.
    04-30-2016 02:37 PM
  6. DEman19901's Avatar
    My problem started around the 15th of April. I had about a three day stretch where everything was working fine. Re installed My Data Manager app and things stopped working again. Uninstalled My Data Manager and reset my APN settings about 3 days ago. Not any problems so far. I know that this is only a temporary solution. I will continue to monitor.
    04-30-2016 03:00 PM
  7. Marc Maeda's Avatar
    EXACT same problem here. Started a couple weeks ago. I've tried a ton of different APN's. Sometimes it'll start working randomly and be good for a day or two. I always still have good download speeds but zero upload. Is this a straighttalk problem or S7Edge problem?
    04-30-2016 11:11 PM
  8. DEman19901's Avatar
    I am guessing it's a Straight Talk problem with the S7 Edge if that makes any sense. I removed the SIM card from my S7 and placed it in my S4 and didn't seem to be experiencing any problems albeit only for a day. I will give it a couple more weeks and I will probably be leaving Straight Talk.
    04-30-2016 11:19 PM
  9. DEman19901's Avatar
    Out of curiosity, is anyone on the new 10GB plan?
    05-02-2016 06:54 AM
  10. getwidit's Avatar
    Bump any word from anywhere to fix this?
    05-02-2016 09:36 AM
  11. the_icon12's Avatar
    Same thing happening to me on my new HTC 10. I'm not sure if there is a relation with newer phones but I have 0 on the upload speed but absolutely fine on the download.
    05-09-2016 02:11 PM
  12. DEman19901's Avatar
    That's interesting to know because up until this point I thought that it was only an S7 problem. I have contacted Straight Talk numerous times but the CS rep had absolutely no clue on resolving the issue. I wonder if Straight Talk is even aware of the problem.
    05-09-2016 02:46 PM
  1. S7 Video Won't Play on My Computer
    By monicakm in forum Samsung Galaxy S7
    Last Post: 02-03-2017, 10:33 PM
  2. What is the current android version for a Samsung SIII?
    Last Post: 04-21-2016, 09:19 PM
  3. Replies: 1
    Last Post: 04-21-2016, 05:00 PM
  4. Outlook calendar syncing problem
    Last Post: 04-21-2016, 04:30 PM
  5. Samsung galaxy centura S738C says it's offline?
    Last Post: 04-21-2016, 03:59 PM
