1. AC Question's Avatar
    I have an LG Volt 2, ls751, with Lollipop 5.1.1. It has Snapdragon 410.
    I am stuck on LG screen at boot. I tried to replace Kingroot with SuperSu. I can say that according to a "root checker" app that I did root successfully.
    I can access both recovery and download screens with hard keys. I tried to factory reset from the recovery menu and did not work.
    All my searching on the internet I found a custom recovery for this phone. Should that be my next step, flash a custom recovery? If so, what tools should I use? The easiest flashing method and tools is essential because I'm kinda noob.
    Is there a safer way to fix my phone other than flashing?
    msgrim likes this.
    04-21-2016 11:19 PM
  2. msgrim's Avatar
    I'm a member.
    04-22-2016 12:33 AM
  3. H3aTeRzz's Avatar
    Hi there
    I'm no familiar with the LG Volt. Dump the custom recovery....Look on Sammobile.com See if you can find our OEM software, then use Odin to flash it to your device. This will bring you back to original factory settings.
    Do a youtube search for using Odin, its relatively easy.
    Hope this helps, Good Luck!
    Chris
    04-22-2016 05:47 AM
  4. sfoLAX's Avatar
    or XDA - developers
    04-22-2016 06:12 AM
  1. Prox sensor is weird...
    By Eclipse2K in forum Nexus 6P
    Last Post: 04-22-2016, 08:11 AM
  2. What is the star in my stats bar at the top of my phone
    Last Post: 04-22-2016, 04:50 AM
  3. Looking for a better Phone
    Last Post: 04-21-2016, 10:41 PM
  4. Replies: 0
    Last Post: 04-21-2016, 10:29 PM
  5. why won't my new Android Moxee X1 Smartphone activate?
    Last Post: 04-21-2016, 10:27 PM
