1. AC Question's Avatar
    I have a ulefone be touch 2 (android 5.1) and its been fine for quite a while but suddenly my battery drops. As in I charge it fully and it drains at a normal rate but I think at around 70% it will drop to around 20% within a few minutes. This hasnt just happened once but its recurring.
    Do I just need to buy a new battery or is there anything else I can do?
    Thanks.
    04-23-2016 05:37 AM
  2. Rainbow Xerneas's Avatar
    Thanks.
    This is what my battery life looks like if it helps
    Imgur: The most awesome images on the Internet
    04-23-2016 05:47 AM
  3. belodion's Avatar
    It could be a faulty battery, but check your battery usage stats for clues after such a discharge.
    04-23-2016 06:07 AM
  4. Rainbow Xerneas's Avatar
    I checked it but there are no apps in particular which have used a lot, most of the usage is on the screen which I keep at the lowest brightness. All it shows is a sudden drop.
    I might just have to buy a new battery.
    04-23-2016 07:38 AM
  1. Replies: 1
    Last Post: 04-24-2016, 06:01 PM
  2. Why there is no star for favorites in my contact list?
    Last Post: 04-23-2016, 09:03 AM
  3. how can i unlock my note4 if i forgot backup password?
    Last Post: 04-23-2016, 04:08 AM
  4. "My boyfriend factory reset one of m" Q&A
    Last Post: 04-23-2016, 04:07 AM
  5. Replies: 0
    Last Post: 04-23-2016, 03:48 AM
