1. AC Question's Avatar
    Hi my tab is samsung galaxy tab 4. The problem is that the volume on the speaker is too low even when it's on 100%.
    But when i put on my headphones its just fine! Please help me
    04-24-2016 09:16 AM
  2. Tim1954's Avatar
    Your speaker holes may be blocked? Wet? Or just broken...
    04-25-2016 07:29 AM
  3. domdo's Avatar
    try to install an equalizer
    04-25-2016 07:33 AM
  4. sfoLAX's Avatar
    There is or was an app called Speaker Clean which sends high frequency noise to vibrate any dirt loose, or some such. Some have had great success on phones. Look it up.
    Edit : it's not there anymore. I wonder why.
    04-25-2016 07:34 AM
  5. zuben el genubi's Avatar
    I think something is built in for your safety.
    I keep getting warnings about loud speakers damaging ears.
    I found an external speaker that uses both bluetooth and rca cable. Couldn't hear the announcers on At Bat. Still get the warning, but turn the speaker up and sound down on the tab.
    04-25-2016 09:05 AM
  1. Fast Wireless Charging Taking Way Too Long (4+ hrs.)
    By Bag of Leaves in forum Samsung Galaxy S7 edge
    Last Post: 05-05-2016, 01:36 AM
  2. How do I get higher volume on Samsung S6
    Last Post: 04-23-2016, 05:09 PM
  3. Low profile SD card that does not stick out
    By twdawson in forum Samsung Chromebooks
    Last Post: 04-23-2016, 08:51 AM
  4. Replies: 0
    Last Post: 04-22-2016, 07:34 PM
  5. Replies: 0
    Last Post: 04-22-2016, 07:27 PM
