I used to have about 2,85GB as System Data. Today, after some apps (the uninstalling) I was it went up to 3,61GB.
After some- unsuccesful- tries to get it back down, I did a Factory Reset.
Right after the Factory Reset the System Data was 4,6GB. I did another Factory Reset and nothing changed.
How come my System Data went UP after a Factory Reset? How can I go back to how things where before?
Thank you,
Thank you,
