1. AC Question's Avatar
    I just got this phone and it worked fine, then the ringtone for texts kept switching back to the very first one I selected (i changed it to one I downloaded) and now it makes no sound at all!
    I've set and reset the notifications in the text settings section.
    Scotty Smith likes this.
    04-28-2016 06:05 PM
  2. Scotty Smith's Avatar
    I have a similar problem with my Hydro View. When I change my message notification sound, it will change back to default sound as soon as I close the text message page. Only if I keep the message page open /running in background/ and don't turn my phone off with it not go back to default. Please help. Very annoying! Its like it won't save the change in settings.
    04-30-2016 08:06 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! Are your custom tones saved to Internal Storage or to a microSD card?
    05-01-2016 01:10 AM
  4. mr4sman's Avatar
    I am having the same issue and I'm using the notification tones through Messenger settings supplied by the phone not custom
    10-05-2016 06:56 PM
  5. GingermcCann's Avatar
    My text notification sound keeps defaulting to Cricket guitar and it's driving me crazy! Don't know how to fix it
    02-19-2017 10:47 PM
  1. Replies: 1
    Last Post: 04-28-2016, 06:03 PM
  2. Replies: 1
    Last Post: 04-28-2016, 05:19 PM
  3. how to delete lazy list on tab 4Del
    Last Post: 04-28-2016, 05:16 PM
  4. Replies: 1
    Last Post: 04-28-2016, 05:09 PM
  5. Replies: 0
    Last Post: 04-28-2016, 04:49 PM
